Hi
Im Not sure if this in the right section but i'm guessing its a motherboard related problem.
Basically sometimes it boots properly but I can be sitting there turning it off and on for a while, usually revolving on turning it off, unplug the cord and replug it in and turn it off. The fans come on, HDD light comes on. Just no scream and usual racket the HDD makes altho i can hear it spinning.
So when it does boot the system works fine. So other components should be fine/
Motherboard is an MSI 870 C45 with an AMD ATHLON II 640 processor.
Cleared the CMOS many a time. Not overclocked.
Could it be that the mobo needs replacing?
thanks guys!
thanks guys!
