Random BSOD... help
22 Feb 2004
Walsall, West Midlands
Hi, i seem to be getting random reboots/BSOD, its been happening now for just over 2 weeks, ive tryed reformatting and tried installing on a different hdd, but keep getting the same errors.
Im not sure if my memory is the problem, but its passed 12hrs of memtest ok, ive ran gfx benchmark software and that seems ok, all my temps seem ok.
Here are the last 4 crashdumps created and all seem to point to "ntoskrnl.exe"
PHP:
Crash dump directory: C:\Windows\Minidump
On Mon 28/12/2009 03:07:09 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x50 (0xFFFFE1B95656A214, 0x8, 0xFFFFE1B95656A214, 0x7)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Dump file: C:\Windows\Minidump\122809-22916-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
On Sat 26/12/2009 14:15:13 your computer crashed
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002AF16C1, 0xFFFFF88006232FC0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Dump file: C:\Windows\Minidump\122609-17269-01.dmp
On Sat 26/12/2009 04:28:30 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF80002A9718E)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Dump file: C:\Windows\Minidump\122609-16707-01.dmp
On Fri 25/12/2009 11:10:11 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF80002A8218E)
Dump file: C:\Windows\Minidump\122509-14445-01.dmp
Whats could be causing my problems ??
Thanks
Andy
Could be your HDD failing?
Try a different cable as suggested above if you can. Not sure of any tools to check Harddrives but someone else might have a suggestion for a tool
Im getting these BSOD on stock settings, No oc''ing on anything
Ive tryed diffrent SATA cables even tryed diffrent hdd (on ATA cable)
And the above report is off Whocrashed.
At the mo ive just reinstalled the OS again but with my memory running @ 800 instead of 1066, just to rule out a memory problem.
Well since yesterday ive been running my memory @ 800 instead of 1066, and guess what.......it aint BSOD once.
so either faulty memory or incorrect bios settings.
So... whats the best config for my memory in bios, my mobo is a Asus P5Q Pro.
Thanks
Andy
what voltage do you have your ram at? It'll require ~2.1V, but your board will default to 1.8VDimm. If you've tweaked the timings or clock speed, you may need 2.2V.
Volts is @ 2.1 all the rest is @ auto.
I just booted back to 1066 went into a game and i got a blue screen, put it back down to 800 and no blue screen
Looks like its RMA time
