Random BSOD :(
22 Aug 2009
Quit L4D2 to goto bed and up pops a BSOD. From the ensuing restart, the desktop failed to load (the mouse was visible and movable, but the taskbar and icons failed to show. ctrl+alt+dlt did work though). Any information shed on it would be greatly appreciated!
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fb49b860, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 9c5482ae, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, (reserved)
Debugging Details:
*** WARNING: Unable to verify timestamp for avipbb.sys
*** ERROR: Module load completed but symbols could not be loaded for avipbb.sys
Could not read faulting driver name
READ_ADDRESS: GetPointerFromAddress: unable to read from 825466d8
Unable to read MiSystemVaType memory at 825272e0
fb49b860
FAULTING_IP:
win32k!ttfdCloseFontContext+16
9c5482ae 8b3e mov edi,dword ptr [esi]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 0
TRAP_FRAME: a9648a70 -- (.trap 0xffffffffa9648a70)
ErrCode = 00000000
eax=fb8dfb60 ebx=fb8dfb60 ecx=87031900 edx=00000000 esi=fb49b860 edi=9c5481e3
eip=9c5482ae esp=a9648ae4 ebp=a9648af0 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010286
win32k!ttfdCloseFontContext+0x16:
9c5482ae 8b3e mov edi,dword ptr [esi] ds:0023:fb49b860=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from 82474b04 to 8248ab9e
STACK_TEXT:
a9648a58 82474b04 00000000 fb49b860 00000000 nt!MmAccessFault+0x158
a9648a58 9c5482ae 00000000 fb49b860 00000000 nt!KiTrap0E+0xdc
a9648af0 9c5481d5 fb8dfb60 a9648b44 a9648b0c win32k!ttfdCloseFontContext+0x16
a9648b00 9c5481fb fb8dfcf0 a9648b28 9c548274 win32k!ttfdDestroyFont+0x16
a9648b0c 9c548274 fb8dfcf0 fc1c5c50 a9648b80 win32k!ttfdSemDestroyFont+0x18
a9648b28 9c547f98 fb8dfcf0 fc1c5c50 fe305cf0 win32k!PDEVOBJ:estroyFont+0x65
a9648b4c 9c5098af 00000000 00000000 00000001 win32k!RFONTOBJ::vDeleteRFONT+0x33
a9648b84 9c509a30 a9648ba8 00000000 fded2354 win32k!vRestartKillRFONTList+0x7b
a9648bb8 9c4becd0 0000001c fded2354 00000000 win32k!PFTOBJ::bUnloadWorkhorse+0x115
a9648be4 9c4be8ca fdc4b008 00000000 00000000 win32k!vCleanupPrivateFonts+0x4d
a9648bfc 9c4bb092 fdc4b008 00000000 00000000 win32k!NtGdiCloseProcess+0x13d
a9648c1c 9c4babd1 fdc4b008 00000000 871cfbc0 win32k!GdiProcessCallout+0x145
a9648c38 82625fe1 85147ad8 00000000 af329cdd win32k!W32pProcessCallout+0x5d
a9648ca4 826265b0 00000000 00000000 84a901e8 nt!PspExitThread+0x4a0
a9648cc0 826331ff 84a901e8 00000000 00000001 nt!PspTerminateThreadByPointer+0x5b
a9648cf0 93d24c67 ffffffff 00000000 ffffffff nt!NtTerminateProcess+0x1e0
WARNING: Stack unwind information not available. Following frames may be wrong.
a9648d54 824719aa ffffffff 00000000 0012fe94 avipbb+0x8c67
a9648d54 772e5e74 ffffffff 00000000 0012fe94 nt!KiFastCallEntry+0x12a
0012fe94 00000000 00000000 00000000 00000000 0x772e5e74
STACK_COMMAND: kb
FOLLOWUP_IP:
avipbb+8c67
93d24c67 ?? ???
SYMBOL_STACK_INDEX: 10
SYMBOL_NAME: avipbb+8c67
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: avipbb
IMAGE_NAME: avipbb.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 49c9008b
FAILURE_BUCKET_ID: 0x50_avipbb+8c67
Followup: MachineOwner
This is all i seem to be able to come up with.
Thanks
From other sources, seems to be from a bug in Avira. Its the first BSOD i've had and i "know" my mobo is on it's way out. I think it's just a wait and see but if anyone can shed more light perhaps?
In my experience a BSOD is almost always a sign of failing hardware. If you suspect Avira as the cause then why not uninstall it and use Avast instead?
I've had one BSOD prior to this one and it was related to a dodgy GPU driver update. I think there are reports of a dodgy Avira 10 file causing problems. Dont know too much though
I've always used Avira (on both big rig and laptop) and never had any problems. Just a case of why fix whats not broken tbh.
But your getting the BSOD so it is broken. Avast is excellent. I know you probably won't change but it doesn't say much for Avira if they can't test their AV program properly to the extent that it does this.
