Random BSOD
30 Dec 2009
Wigan Lancs
I am getting a random BSOD, no set pattern it just happens at any time.
When the BSOD appears it says IRQL-NOT-LESS-OR-EQUAL
My system has two separate hard drives each with it's own OS and this happens no matter which i boot from.
I suspect this is a hardware issue because of this and a bit of Googling seems to say it's a RAM issue??
Is this correct as i am not entirely sure.
Thanks.
Note.. i have made no hardware changes recently.
If that doesn't work, check your IRQs (System Information -> Hardware Resources -> IRQs)
I had this same problem shortly after I updated graphics drivers a while back - for some reason it decided to give the graphics card the same IRQL as the wireless card, causing this BSOD seemingly randomly!
