Hi guys... I started having random bsod's, not so regularly, like maby once or twice a day. I tried removing the mild OC on my gpu, no difference, tried removing OC on my CPU ( been stable for 2 years ) and like I expected no difference.
A day or so later the bsod's became more regular, and I started getting bsod's as soon as I reached desktop having just recovered from a bsod...This then turned into bsod's well I was rebooting from a bsod... leaving me unable to even get into the bios, this happened maby 3-4 times well trying to boot up, and ended in the PC just seemingly powering itself off, funny thing is after it did this is it powered up (fans and lights etc) for 1-2 secs then fully off.
I turned it off at the rear since then and not tried anything else...
Im inclined to believe this is PSU or motherboard related, im using a corsair HX 750, and MB is an asus P6X58D-E I think
I have contacted OCUK as both parts are under warrenty with them, however they require me to test... and work out wich one if either is at fault, I do not have spare parts, or even much spare time right now to go ripping my HAF-X build apart.....That together with no spare PSU or Mb to test, well.. this leaves me in a troubled spot.
Any advice/ideas ?
.I have contacted OCUK as both parts are under warrenty with them, however they require me to test... and work out wich one if either is at fault, I do not have spare parts, or even much spare time right now to go ripping my HAF-X build apart.....That together with no spare PSU or Mb to test, well.. this leaves me in a troubled spot.
Any advice/ideas ?
