- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
I have the dreaded Kernel power errors started up since I swapped out an air cooler for a AIO.
Temps are fine and low. Nothing over heats. The crash occurs usually while there is no massive load as such.
Randomly after around 24 hours, the system will crash. Sometimes it can be a nightmare getting it back on but I think I have sussed out to power off for a few seconds and power up again and it will boot.
This all started while I was swapping the cooler, the CPU was stuck to the old cooler. I twisted it and while doing so, inadvertently lifted it and got some pins bent and also some compound on the socket. I spent hours sorting the pins out with a needle. They were all straightened OK as far as I could tell. I cleaned off the paste to the best I could with IPA and refitted the CPU. It would not boot. I removed and replaced it a few times, made sure the cooler was not quite as tight, then it booted OK.
Things started going wrong again, it will reboot as above now. I also swapped RAM after but changing back to old makes no difference.
AMD 3900x
Asus x370 pro board
2 * 16gb Corsair RAM.
I plan to remove the CPU and give it all a good clean with IPA later. If this fails, I plan to get a 2nd hand 570 board and see if this helps.
Any input would be good.
AMD 3900x
Asus x370 pro board
