Random crashes
17 Dec 2009
Hi guys.
I am having a series of random crashes. I think mostly when the computer is running hot, I have done a mem test and it identified the ram was at fault, I took out both sticks, tried one at a time, and 1 doesn't have errors but 1 does.
I think my computer might just be falling apart generally, but ideally rather than starting from scratch I would want to keep this PC as im not a heavy user anymore and I don't need to spend £1500+ on a new PC/Graphics card.
This is the error I get according to the program "Whocrashed"
Can anyone identify why this is happening?
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Fri 03/12/2021 23:34:38 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\120321-10140-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F72A0)
Bugcheck code: 0x124 (0x0, 0xFFFFCC08F45E1028, 0xBC202000, 0xC0135)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
My crystal ball crashes 100% of the time I try to ask it about parts in your PC...
Though any memory errors aren't good thing
