- 20 Aug 2012
- Greater London
i have an m-itx motherboard with 4gb RAM, and some AMD athlon CPU @ 2.60ghz (can't remember which 1, possibly X2) and stock AMD fan because nothing i had fitted in the tiny case. anyway, it keeps cutting off visuals, so when i'm just doing something on it the screen will stop getting info from the machine, and go into power saving mode, although the computer will still run like nothing happened. tried this machine on 28" screen and 17" screen (17" VGA, 28" DVI) and the display but off on both. i don't know whether it's a problem with the HDD, as it tends to shut off mostly during reading and writing data, although it also has trouble booting into windows.
The CPU also reaches 50 degrees on idle, which is strange, and even when i replaced thermal paste, which brought temps down to 29 degrees, the same problem occurs.
Any ideas what might be causing this?
Sorry about lengthy description, but i can't shorten it...
