- 25 Mar 2003
- Birmingham
Help me out here guys, random FPS drop whilst playing WoW, gathered some logs which i'll post below.
Spec:
i5 - 3750k @4.2
16Gb RAM
GTX 770 Jetstream
Games on Crucial M4.
The drop seems to be happening from 11:56:25 to 11:56:40 but what is causing it?
Spec:
i5 - 3750k @4.2
16Gb RAM
GTX 770 Jetstream
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , Power Consumption [% TDP] , PerfCap Reason [] , VDDC [V] , VDDC Current [A] , VDDC Power [W] ,
2013-10-12 11:56:00 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 990 , 80 , 37 , 0 , 76.4 , 4 , - , 59.4 , - ,
2013-10-12 11:56:01 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 990 , 83 , 40 , 0 , 79.4 , 4 , 1.169 , 66.8 , - ,
2013-10-12 11:56:02 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 990 , 87 , 42 , 0 , 81.7 , 4 , 1.175 , 42.6 , 49.7 ,
2013-10-12 11:56:03 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 990 , 68 , 33 , 0 , 72.3 , 4 , 1.175 , 56.6 , 66.2 ,
2013-10-12 11:56:04 , 1267.3 , 1752.8 , 69.0 , 40 , 1110 , 990 , 66 , 28 , 0 , 72.4 , 4 , - , 51.4 , - ,
2013-10-12 11:56:05 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 990 , 74 , 31 , 0 , 71.3 , 4 , 1.181 , 59.0 , - ,
2013-10-12 11:56:06 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 990 , 84 , 41 , 0 , 79.2 , 4 , 1.169 , 66.0 , 77.1 ,
2013-10-12 11:56:07 , 1267.3 , 1752.8 , 70.0 , 40 , 1080 , 991 , 86 , 43 , 0 , 80.4 , 4 , - , 66.4 , - ,
2013-10-12 11:56:08 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 989 , 73 , 32 , 0 , 75.2 , 4 , 1.188 , 62.1 , 72.7 ,
2013-10-12 11:56:09 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 71 , 31 , 0 , 73.9 , 4 , 1.175 , 58.4 , 68.5 ,
2013-10-12 11:56:10 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 71 , 30 , 0 , 73.6 , 4 , 1.175 , 59.2 , - ,
2013-10-12 11:56:11 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 71 , 30 , 0 , 70.2 , 4 , 1.175 , 59.6 , - ,
2013-10-12 11:56:12 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 989 , 77 , 33 , 0 , 74.3 , 4 , 1.169 , 60.5 , 71.8 ,
2013-10-12 11:56:13 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 69 , 30 , 0 , 72.1 , 4 , - , 32.8 , 38.3 ,
2013-10-12 11:56:14 , 1267.3 , 1752.8 , 69.0 , 40 , 1110 , 988 , 70 , 30 , 0 , 70.4 , 4 , - , 58.8 , - ,
2013-10-12 11:56:15 , 1267.3 , 1752.8 , 68.0 , 40 , 1080 , 988 , 74 , 32 , 0 , 71.2 , 4 , 1.175 , 61.5 , - ,
2013-10-12 11:56:16 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 68 , 29 , 0 , 72.9 , 4 , 1.169 , 59.4 , - ,
2013-10-12 11:56:17 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 73 , 31 , 0 , 73.8 , 4 , 1.175 , 54.3 , 63.7 ,
2013-10-12 11:56:18 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 988 , 76 , 34 , 0 , 74.9 , 4 , - , 43.2 , - ,
2013-10-12 11:56:19 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 989 , 79 , 35 , 0 , 78.1 , 4 , 1.169 , 63.1 , - ,
2013-10-12 11:56:20 , 1267.3 , 1752.8 , 68.0 , 40 , 1080 , 988 , 60 , 26 , 0 , 71.6 , 4 , 1.175 , 58.0 , 67.8 ,
2013-10-12 11:56:21 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 989 , 77 , 38 , 0 , 74.6 , 4 , - , 55.7 , 65.0 ,
2013-10-12 11:56:22 , 1267.3 , 1752.8 , 69.0 , 40 , 1080 , 989 , 68 , 33 , 0 , 71.1 , 4 , - , 24.0 , 28.5 ,
2013-10-12 11:56:23 , 1267.3 , 1752.8 , 64.0 , 40 , 1080 , 989 , 9 , 4 , 0 , 41.0 , 4 , - , 16.6 , - ,
2013-10-12 11:56:24 , 1267.3 , 1752.8 , 64.0 , 40 , 1110 , 988 , 10 , 4 , 0 , 39.0 , 4 , 1.194 , 17.0 , - ,
2013-10-12 11:56:25 , 757.7 , 1752.8 , 61.0 , 40 , 1080 , 988 , 14 , 4 , 0 , 29.7 , 0 , 0.881 , 13.7 , - ,
2013-10-12 11:56:26 , 757.7 , 1752.8 , 60.0 , 40 , 1080 , 988 , 14 , 4 , 0 , 28.5 , 0 , 0.875 , 7.8 , 6.8 ,
2013-10-12 11:56:27 , 757.7 , 1752.8 , 60.0 , 40 , 1080 , 988 , 15 , 5 , 0 , 28.0 , 0 , - , 7.6 , 6.7 ,
2013-10-12 11:56:28 , 561.8 , 405.0 , 58.0 , 40 , 1110 , 988 , 27 , 20 , 0 , 16.2 , 0 , - , 19.1 , 16.6 ,
2013-10-12 11:56:29 , 561.8 , 405.0 , 58.0 , 40 , 1080 , 988 , 24 , 20 , 0 , 16.3 , 0 , - , 6.3 , - ,
2013-10-12 11:56:30 , 561.8 , 405.0 , 57.0 , 40 , 1080 , 988 , 20 , 17 , 0 , 15.9 , 0 , 0.875 , 5.3 , 4.6 ,
2013-10-12 11:56:31 , 405.0 , 162.0 , 57.0 , 40 , 1080 , 988 , 47 , 41 , 0 , 14.1 , 0 , - , 3.1 , - ,
2013-10-12 11:56:32 , 405.0 , 162.0 , 56.0 , 40 , 1110 , 988 , 48 , 42 , 0 , 14.0 , 0 , 0.850 , 3.1 , - ,
2013-10-12 11:56:33 , 324.0 , 162.0 , 56.0 , 39 , 1080 , 988 , 44 , 37 , 0 , 13.1 , 0 , 0.850 , 6.1 , - ,
2013-10-12 11:56:34 , 324.0 , 162.0 , 55.0 , 39 , 1080 , 988 , 46 , 38 , 0 , 13.2 , 0 , 0.850 , 3.5 , - ,
2013-10-12 11:56:35 , 324.0 , 162.0 , 55.0 , 39 , 1050 , 987 , 47 , 39 , 0 , 13.5 , 0 , 0.850 , 14.1 , 11.9 ,
2013-10-12 11:56:36 , 324.0 , 162.0 , 55.0 , 39 , 1080 , 987 , 58 , 48 , 0 , 13.7 , 0 , 0.850 , 2.9 , 2.5 ,
2013-10-12 11:56:37 , 324.0 , 162.0 , 54.0 , 39 , 1080 , 987 , 55 , 45 , 0 , 13.7 , 0 , 0.850 , 12.3 , - ,
2013-10-12 11:56:38 , 324.0 , 162.0 , 54.0 , 39 , 1050 , 987 , 53 , 44 , 0 , 13.5 , 0 , 0.850 , 3.1 , - ,
2013-10-12 11:56:39 , 324.0 , 162.0 , 54.0 , 38 , 1020 , 988 , 50 , 42 , 0 , 12.8 , 0 , 0.850 , 11.5 , - ,
2013-10-12 11:56:40 , 324.0 , 162.0 , 53.0 , 38 , 1050 , 988 , 47 , 39 , 0 , 13.3 , 0 , 0.850 , 4.9 , 4.1 ,
2013-10-12 11:56:41 , 1267.3 , 1752.8 , 58.0 , 38 , 1050 , 988 , 64 , 30 , 0 , 53.3 , 4 , 1.181 , 47.7 , - ,
2013-10-12 11:56:42 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 986 , 58 , 26 , 0 , 63.6 , 4 , 1.181 , 52.9 , - ,
2013-10-12 11:56:43 , 1267.3 , 1752.8 , 60.0 , 38 , 1050 , 986 , 60 , 28 , 0 , 63.7 , 4 , 1.175 , 24.6 , 28.9 ,
2013-10-12 11:56:44 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 986 , 59 , 27 , 0 , 62.3 , 4 , 1.181 , 29.3 , - ,
2013-10-12 11:56:45 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 989 , 49 , 21 , 0 , 57.6 , 4 , 1.181 , 38.1 , - ,
2013-10-12 11:56:46 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 989 , 49 , 21 , 0 , 58.6 , 4 , 1.181 , 31.8 , 37.6 ,
2013-10-12 11:56:47 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 989 , 44 , 18 , 0 , 56.2 , 4 , - , 36.7 , 43.2 ,
2013-10-12 11:56:48 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 989 , 47 , 20 , 0 , 60.7 , 4 , 1.181 , 49.8 , - ,
2013-10-12 11:56:49 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 989 , 50 , 21 , 0 , 57.8 , 4 , 1.181 , 37.3 , - ,
2013-10-12 11:56:50 , 1267.3 , 1752.8 , 59.0 , 38 , 1020 , 989 , 47 , 19 , 0 , 55.1 , 4 , 1.194 , 29.7 , - ,
2013-10-12 11:56:51 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 992 , 45 , 18 , 0 , 55.3 , 4 , 1.181 , 38.3 , 45.1 ,
2013-10-12 11:56:52 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 992 , 50 , 21 , 0 , 59.5 , 4 , - , 41.0 , - ,
2013-10-12 11:56:53 , 1267.3 , 1752.8 , 60.0 , 38 , 1020 , 993 , 60 , 28 , 0 , 60.5 , 4 , 1.181 , 44.5 , - ,
2013-10-12 11:56:54 , 1267.3 , 1752.8 , 59.0 , 38 , 1020 , 993 , 26 , 14 , 0 , 48.4 , 4 , 1.188 , 26.4 , - ,
2013-10-12 11:56:55 , 1267.3 , 1752.8 , 59.0 , 38 , 1020 , 993 , 30 , 18 , 0 , 50.3 , 4 , 1.194 , 33.6 , 39.6 ,
2013-10-12 11:56:56 , 1267.3 , 1752.8 , 58.0 , 38 , 1020 , 1034 , 9 , 1 , 0 , 36.6 , 4 , - , 17.2 , - ,
2013-10-12 11:56:57 , 1267.3 , 1752.8 , 56.0 , 38 , 1050 , 961 , 1 , 0 , 0 , 34.2 , 4 , 1.194 , 15.4 , 18.3 ,
2013-10-12 11:56:58 , 1267.3 , 1752.8 , 56.0 , 38 , 1020 , 961 , 0 , 0 , 0 , 34.0 , 4 , 1.194 , 15.4 , 18.3 ,
2013-10-12 11:56:59 , 1267.3 , 1752.8 , 56.0 , 38 , 1020 , 961 , 0 , 0 , 0 , 33.9 , 4 , 1.194 , 15.0 , 17.9 ,
2013-10-12 11:57:00 , 1267.3 , 1752.8 , 55.0 , 38 , 1020 , 961 , 0 , 0 , 0 , 33.9 , 4 , - , 15.6 , - ,
