Hi guys,
I've tried my best to diagnose this problem but I don't know what might be causing it. Recently, my computer has started freezing. No BSOD, no restarts, just a complete lock up with the mouse frozen. It's not down to heating or load on the system because the temps are fine and it sometimes happens when it's idling.
I've run memtest86+ on the memory and no errors are reported. I read somewhere that the motherboard sometimes has timing issues with memory so I got the proper timing values from the qvl and entered them in manually, but this didn't rectify the problem. I've reformatted and this has not fixed it. I've run the manufacturer diagnostic tools on the hard disk but it came back fine.
There are no relevant errors in the event viewer, short of "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly." It looks like a hardware issue of some sort, but I'm lost as to where it could be. Could my motherboard be failing?
The spec is below in case there's anything I might have missed.
CPU: Intel i7 920 2.66 GHz Nelahem
MB: Asus P6T Intel X58 DDR3
RAM: OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel (OCZ3G1600LV6GK)
OS: Windows 7 64 bit Home Premium
GPU: Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express
HDD: Western Digital Caviar Black 1TB SATA-II 32MB Cache
PSU: Corsair TX 650W ATX SLi Compliant
Edit: Oh, by the way, I've also updated the motherboard bios to the latest version and that didn't fix it.
