Random Freezing and Restarts
9 Jun 2009
Hi, so I built my bro a new PC, and everything is working dandy, except When he plays games i.e the new Tomb Raider, after about 45 mins/1 hour or so it will blue screen and restart, and there is no obvious reason for this... I have checked temps after restart, and they are all well within the safe zone.
Any Ideas? Im doing a fresh install to see if that cures it, the only non ordinary thing is he has 3 monitor eye finity setup, and all the monitors are VGA, so have a converter on each one.
Thanks in Advanced. Dan
It isnt overclocked, everything stock.
Ill get back to you on blue screen message, its at this house atm
pc specs:
-Intel Core i5 3570K 3.4GHz Socket 1155 6MB Cache Retail Boxed Processor
-Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Sport Memory Kit CL9 (9-9-9-24) 1.5V
-Coolermaster Elite Power 500W PSU
-Asus P8Z77-V LX Socket 1155 VGA DVI HDMI 8 Channel Audio ATX Motherboard
-Sapphire HD 7870 GHZ OC Edition 2GB GDDR5 Dual DVI HDMI DisplayPort PCI-E Graphics Card
you could try with 1.55v dram voltage and set the power control slider to 20% in ccc/overdrive settings,it doesn't add any voltage it just raises the thermal limits,my 7850 needs it set to 10%
