Random Hardware
21 Jul 2004
Harrow, UK
Every time I boot my PC it says it needs to install some hardware (and there are two Unknown Devices in Device Manager) but I don't have a clue what they are.
Everything is installed as far as I know :confused:
In my experiance an unknown device can be a gameport on a soundcard (even if it dosent have one :confused:) or quite offten its a motherboard "device" which is what the motherboard monitoring programs "tap into" to get your temps and stuff.
So for example if you've got an Asus board try installing AiBooster and see if it goes away..
just an idea
ta
alec
Ah ha! So I was right. You haven't installed the drivers then. What you've installed are drivers for the main socket. You need to install seperate drivers for the WDM part of the card.
This caught me out with my X1800XT until I realised this.
http://ati.amd.com/support/drivers/xp/radeonxip-xp.html There you have 3 packages. The first is the main display, you've installed this. Ignore the second.
The WDM is the third package. That's what you want.
I downloaded the full package:
http://ati.amd.com/support/drivers/xp/radeonx-xp.html
And ticked WDM during the installation...
No, I mean I did that when I first installed the drivers... but let me try it again too :)
Ah sorry. Misunderstood you. Doubt that entry in Device Manager is the WDM bit of you graphics card then.
Right-click on the entry and see what info it says about the hardware. Any clue as to what it might be?
I tried that Halfdone thing, and it says the two unknown devices are to do with NTativrv01 which I believe is the WDM thing :confused:
Any chance of a screenshot of the Device Manager entry and the results from the Halfdone thing?
Gigabyte GA-K8NXP-9
AMD Opteron 165 (2.7 Ghz)
1 GB PC3200 RAM
ATi Radeon 1900XTX
Audigy 2
What have you got plugged in your usb slots?
Open device manager and unplug every device you have. If it dissapears when you unplug something its an external device. If all devices have been unplugged then its something inside the pc.
