Hi Guys,
First off sorry for this hideously bad layout of a post but i'm having major issues with my pc locking up or BSOD on me recently so i've a bulletpoint list of problems/noteworthy actions as they occurred.
Computer Spec
Computer age is around ~6 years and has not been changed since it was bought, all from overclockers shore no less.
Gigabyte EX58-UD3R
Core i7 8core 920 @ 2.7
ATI AMD Radeon HD 4870
3x2GB DDR3 RAM
Vista Ultimate x64
1000w modular PSU
26" LCD TV as monitor via HDMI which is changed to 32" LED TV monitor Via HDMI
Problems/fixes in order of occurrence, some may not be relevant but thought i'd best include info anyway.
Sorry if this bulletpoint diary of problems is messy but it the easiest way to give an accurate timeline of what happened what i tried to resolve it
I've read through a similar post to mine posted not long ago on here, people where saying to remove parts from the computer, i am however ham fisted and have no finesse with fragile parts so removing hardware from the tower isn't an option for me to test things.
People i've spoken too about these problems have said it could be a range of things, damaged/dieing RAM/PSU/GPU but what do you guys think?
Thanks in advance
Computer Spec
Gigabyte EX58-UD3R
3x2GB DDR3 RAM
Vista Ultimate x64
1000w modular PSU
- Weird GFX bug/ BlueSOD when playing Metro Last Light
- Few days later tried the game again, same problem.
- Windows update installs overnight, external speakers on PC stop working and require to be unplugged/plugged back into the rear of PC before working again. Volume mixer has weird graphical error. Several days/reboots later speakers begin to function without needing unplugged and mixer graphic error stops
- Computer BSOD when playing eve online "physical memory dump"
- LCD TV i was using as a monitor begins to have problems, can't start itself from standby, required power to be turned off completely for several hours before attempting to turn on again.
- Computer froze up on boot up followed by a BSOD and another freeze "ati *something*.sys driver failed to load"
- Tried removing latest windows update, no change.
- Updated GFX card drivers threw device manager, driver updated with no change
- Used windows tool to check RAM - no problems reported
- LCD TV dies altogether, replaced with LED TV
- Several computer lock ups shortly after booting, one occurred when changing tab from notepad to firefox
- Started monitoring gfx temperatures, sitting at 81d (never seen i read anything different from day of purchase)
- Took manual control of gfx card fan via CCC/ATI overdrive, keeping temperatures below 60d - setting fan speed to 100% when trying to load a game which doesn't seem to help as BSOD/Freeze happens shortly after
- Noticed that under device manager "AK3LOFAL IDE Controller" is flagged "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
- " - used "update driver" option with no success, flag is still there.
- Downloaded and attempted to install CCC, installer reported that it is already installed and everything was up to date
- Uninstalled GFX car via safe mode, restarted computer to self install, nothing changed
- Blew out excessive dust from case and removed side panel to reduce CPU + GPU temps (-10d of both)
- Noticed that something in the tower (i suspect GFX card) makes odd sanding/griding noise when under strain, such as loading a game or moving around an image with the grab tool in windows media gallery.
Noise happens after i try to load a game which causes system lockup/bsod shortly afterwards. Note the grinding noise does not appear to be the cooling fan.
- Icon for network connection beside clock is showing as not connected, yet computer is connected to Internet and working fine
- - Posts ramble on overclocksers forum
Thanks in advance
