random lockup
9 Dec 2006
@ManCave
on my pc at random times the pc total locks up somtimes with no mouse icon somtimes with a mouse icon
pc does not respond to anything other than the power button :(
ive limted to down to:
graphics card - reason being when moving windows i get bar code like effect (even though his was replaced recently) as last card had same issues with lockup and cleared up after i got this new gpu
memory - as program takes log while to load somtimes 30 secs for FF3! plus windows that overlap other windows somtimes are seethrough
soundcard - seem to happen since i got the card and didnt seem to happen with usb soundcard...
ive uninstalled the soundcard drivers to see if its that, and running memtest3.3 atm to test memory
anything ive overlooked or forgot??
spec in sig
temps, could be an overheating problem,
take apart the gpu and check the thermal paste hasn't dried up
Have you overclocked anything? if so set it lower
no overclock amd temps are fine
44c
51c
44c
51c on cpu
32C-45C on graphics card (2x120mm fans over it)
