- 24 Jun 2003
So my pc was running fine for a year or so with no issues until i recently upgraded my graphics card from a Radeon hd 7950 3GB to a https://www.overclockers.co.uk/showproduct.php?prodid=GX-351-SP as per the following post :
http://forums.overclockers.co.uk/showthread.php?t=18668626
My psu is a thermaltake tough power 600w
It has now been one month since the upgrade and all seemed fine at first but now just in the last week the pc has just shut down like 4 times always while playing a heavy intense game.
the restart is just like someone had pulled out the power lead on the pc,, there is no freezing of the computer, not bsods noting at all , just like the power had went of, and once i restart the PC it will run fine ( just the usual boot option to restart windows normally as it was not shut down correctly message at restarting. )
the first time it did it i thought temps or load,, so i loaded up core temp,, gpu temp and the task manager to monitor cpu usage.
cpu and gpu temps were fine same for cpu usage.
to me it deffo sounds like the PSU is right on the limit and the shut downs are caused by the power starvation is there a way to check this ?
and do you think i am right or could it be something else ?
p.s ill run mem test later just to rule that out.
