Random Pings?
Permabanned
29 Aug 2003
Sometimes by BY connection starts playing up. Its normally fine, with pings in CSS normally between 25-60 for first load of servers...
Then it will start coming up with connection problem I'll get disconnected then everything starts from pings roughly 180+ :confused:
For example a quick ping of www.bbc.co.uk got:
Pinging www.bbc.net.uk [212.58.224.89] with 32 bytes of data:
Reply from 212.58.224.89: bytes=32 time=163ms TTL=245
Request timed out.
Reply from 212.58.224.89: bytes=32 time=164ms TTL=245
Reply from 212.58.224.89: bytes=32 time=162ms TTL=245
Ping statistics for 212.58.224.89:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 164ms, Average = 163ms
:confused: Its got to be a connection fault I would have thought?
I've removed router, modem is direct to NIC and its be re-started several times.
Any thoughts?
hmm, packet loss is never good when trying to game. If it's not any better by the time you read this log it with tech support, they will most likley ask for a tracert as well as ping data.
