Random problem, any help? :(
I have an 8800GTS sat here with a blown capacitor and it does the same as you have seen. Take your card out and check for any blown components.
Mines repairable..wonder if anyone would buy it...
Depends on the brand. check the relevant website! some card manufacturers offer between 2 and 5 years warranty.
Oven trick! Oven trick! Just search the forums for 8800 and oven trick. There may be hope for your card yet. Worked on mine when I had similar symptoms.
