Random Robocopy query
23 Mar 2007
Essex
Hi All
Had a random thing ocour this evening when running a robocopy script. It was a very basic one back up one of my drives. I used the following switches...
Robocopy Z:\Photos B:\Test /E /S
The folder 'Test' was not actually on the B drive i was hoping robocopy would create this for me. Anyway the copy started and then finished off with a permission error on the B drive. Went to the drive and tried to manually create a folder called 'Test', windows then tells me there is already a folder called this in the root of the drive. The strange thing is there isnt! Its not hidden or anything.
Cant understand why windows is telling me that there is a folder with this name already in the root of the drive when its clearly not visually there
Any ideas? Im running Windows 10
Open up cmd
Type in..
CD b:
Press enter
Dir
Press enter
See if it lists it..
Edit, you don't want E and S, just E.
Edit 2, I just ran the command and it created the folder for me
Hi Bledd, thanks for that. I found the problem, it seems to be once the folder is copied it hides the folder as a system temp folder. No idea why its doing this very odd indeed. For now i have reverted to xcopy until i can figure out why its doing this
I have had this before
It happens because you are coping a folder on the root of a drive
after your robocopy line in your script add
attrib B:\Test -h -s
This will will unhide the folder after the copy
