Random shutdowns underload
10 Feb 2006
London
Hi All, been a while. Long time on OCUK, builder of many systems and customiser. Having a really annoying issue i'd like to clear up. PC as per sig running stock, was running fine but has started to have random restarts. I suspect its psu/cable related, psu is an evga p2 850 which has been solid until recently, when under load it just resets randomly after a 10 mins or so gaming. Tried without the gpu, took it out and used the mobo hdmi same issue. All under custom water loop as per sig, temps are all fine usually a 5-10 delta on ambient I run big rads (6x140) on low rpm fans for as quiet as i can get, usually dont even need the fans. Fan cortoller is an fc6 i think, been a while. Best to just rma? Think one of my cables has gone bad? Any help would be greatly appreciated, cheers folks.
Run memtest (with xmp disabled and enabled and see if it fails), I see you have the patriot viper sticks of ram.. They are known for issues and many people find they do strange things in systems or just randomly develop bad areas.
