Random Shutting down
16 May 2004
Near Chester
i am experiencing an incredibly annoying problem of the computer shutting down randomly!! no idea why, i got hold of speed fan and here are the results.....
anything here suspect?
running a
HIS ATI Radeon X1950 Pro
Gigabyte GA 965P DS3
GeIL 2GB (2x1GB) PC2-6400C4 800MHz
Intel Core 2 Duo E4300
Vista 64bit
cheers for any help people!!
Try memtest on the RAM, see if it brings back any errors just so you can rule that out.
Is anything shown when shutting down ? blue screen or anything ?
Anything overclocked ?
ok, so psu a possible suspect, anyway to test it? or best way process of elimination, just opened the pc and played made sure connections were proper and rebooted to get these voltages.....
i notice a few figures have changed? do these look any better, when i started the computer it did make a long beep... am just checking to see what this might mean
I know these s/ware voltage readings are to be taken with a large pinch of salt, but -16.97V on the -12V line seems excessive. To fault find is to swap components, & the first thing I'd beg or borrow is a PSU.
