Ok so I've had this annoying problem for a while now and need to try and get to the bottom of it...
Every so often at random times, my system freezes entirely and I'm forced to hard reset, however when I hard reset my PC doesnt boot because the HDD Boot priority gets messed up.
When I enter the bios all I see are my 2 SATA drives, my Corsair LS is missing until I cut the power completely, hold the power button down for a few seconds, then reboot.
Then I have to manually set my SSD as primary boot boot in the bios and everything is ok again for a few days/weeks until the next time it happens.
My specs are i7 4770k OC to 4.6 (crash happens with or without OC)
MAXIMUS IV EXTREME
16gb Corsair dominator ram @ 1866mhz (crash happens even when down clocked)
r9 280x
EVGA 750W PSU
I've tried resetting everything to optimal defaults and the problem still persists.
I have no idea if its hardware/software, Ram/cpu or SSD causing the problem and not sure where to start troubleshooting without buying replacement components I may or may not need.
Any ideas would be greatly appreciated.
MAXIMUS IV EXTREME
r9 280x
EVGA 750W PSU
