Hi,
At school, we're in the process of upgrading the network to support a new web design course next academic year. The last 'upgrade' was three years ago when we moved from an RM network of just 50 computers to a Ranger network of about 160 computers. The current network is run by a single 2GHz Xeon with 1GB RAM and the hard disk on it is rapidly filling up (It's an IDE disk- don't ask, Zentek did it) As I just mentioned, it was Zentek who installed this network. Clients computers vary really from 400-600MHz Celerons to 3GHz P4's. We've got 40 tablet computers which are pretty good supported by several wireless AP's and most of the staff now have laptops.
I don't want replies like 'they're both crap, you don't need them' as the network manager has decided to go for one of these management solutions but we're not quite sure which one yet. I also don't want replies like we're not doing you're job for you- it isn't my job either but i'm merely trying to help- we're just looking for people's opinions on which is the better software to use. The options are therefore either:
1.) RM
2.) Ranger AND Zentek Solutions
RM seems to be the cheaper software as it includes windows licenses (Have a site Win XP License but are currently using Win Server 2000 and will be intending using Server 2003 so we will need to get licenses one way or another) but it seems that it's liking taking a step back as we've used it before.
Really would appreciate any replies and people's experiences with either security suites
Thanks
Ben
1.) RM
Thanks
Ben
) is a laser printer, wireless access point for the machines and a network switch. The switch is then plugged into a netowkr socket on the wall. All the chargers and stuff are onboard as well so the kids just plug them back in at the end of the lesson.
We also have 8 spare tablets located in the server room which can be borrowed if a class does not have enough computers to go around (Class sizes vary widley) Reliability wise it seems fine. We had a few initial teething problems with Ranger Timing out because on some tablets the connection was too slow but we solved this with a patch from Ranger.
The access points are just plugged in and out of students tampering reach so the entire school has access
