Rank system in a query
18 Oct 2002
Milton Keynes
Hey all
Trying to work out how to get a users rank in a voting system i have
basically the top 10 (or more) is displayed by the following
SELECT vl_cat_id, count(vl_username), vl_username, vl_whovoted FROM vote_log WHERE vl_cat_id = '$vote_cat' GROUP BY 'vl_username' ORDER BY 'count(vl_username)' DESC LIMIT $limit
anyways on the users page i need to show their rank in the voting chart, so how would i do the above, but with WHERE...AND vl_username = '$username' as well. But then to show which position in the query it was at?
Need to do it without working out the whole table, as there will potentially be out of quite a few members
Create an integer variable and increment it manually in a loop, either echoing it or assigning it to an array along with the database data.
A similar example:
PHP:
* MySQL example
$query = mysql_query('SELECT vl_cat_id, count(vl_username), vl_username, vl_whovoted FROM vote_log WHERE vl_cat_id = \'' . $vote_cat . '\' GROUP BY \'vl_username\' ORDER BY \'count(vl_username)\' DESC LIMIT ' . $limit);
$i = 1;
while($row = mysql_fetch_array($query))
 echo $i, ' - ', $row['x'];
 $i++;
Aye, but that gets inefficient with a large number of members. I'd guess one way to do it is to cache the data in a table and periodically run a script to update it.
The appended limit and nature of the script (presumably top X ratings) made me think that it wouldn't really be necessary for caching or other performance-related measures.
However I'm slightly intrigued as to what's inefficient about incrementing a variable, even when in a large loop. I've not run into any sorts of performance issues doing this with pretty large loops (obviously with massive loops performance is hindered anyway.)
The OP is looking for a way around having to loop through every row basically - the LIMIT is just for the 'top 10' bit - he's asking about how to display a user's rank on their member page :)
I agree on the loop suggestion, that was what I suggested to him hehe :D
