Raptr alternative?
16 Jun 2013
I know its done to death thread wise but does anyone know of a raptr alternative yet?
Still seems to be the only one offering the DVR like functionality that Shadowplay has. Unfortunately its becoming rather buggy (at least in my current experience).
AMD only obviously otherwise I'd just use shadowplay :D.
Should add I don't have windows 10 so cant use the inbuilt one.
*crosses fingers*
Action uses GPU and does replays you can try the free version.
I never had any issue with Raptr still use it now and then.
never had any problems with raptr, apart from the weird looking creature they use as their logo! not sure I like the look of that thing at all.
Maybe I've borked something then. It seems to randomly stop working. Every so often play.tv clip viewer freezes and crashes the desktop forcing a complete restart.
I'll try reinstalling if not I'll look into action thanks :).
Try uninstalling and also delete the profile folder found in C:\Users\ username\AppData\Roaming
Then reinstall
Then reinstall
It seems to delete it for you. Regardless I reinstalled and deleted the roaming contents now it's rebuilt it's files it seems to be without issue. Fingers crossed.
