Raspberry Pi 3 DHCP help
18 May 2010
London
Brand new Pi v3.
I'm trying to get it some network connectivity.
It has booted up out of the box with a 192.168.1.25 IP whilst we use 10.2.1.x in the office.
In the /etc/network/interfaces file it is set to: iface eth0 inet manual
I've tried setting iface eth0 inet dhcp and restarting but no dice.
Eventually we will need to give t a static IP, but I am initially trying to get it operational via DHCP.
Anyone have any ides?
I have obviously looked at the official documentation.
OK, not to worry, I plugged it in to the telephone network.
But.... stll no DHCP.
/etc/network/interfaces file it is set to: iface eth0 inet dhcp
Picks up 169 address...
I assume your interface file is as follows
auto eth0
also run
dhclient eth0
try restarting the NIC - obviously not when connected via SSH or Telnet
ifdown eth0
ifup eth0
Next problem is I have managed to install chromium, but it wont run.
Any ideas?
I ran sudo apt-get install chromium-browser.
It installed hat looks like Chromium and see the menu entry.
But it doesn't open when I run it.
Any ideas?
check permissions of the executable - try running it as root to see if it runs, if it does then permissions issue
