Finally received my rev2 raspberry pi but I can't get it to output to display correctly.
I formatted 3 sd cards and put noobs on all of them. Turned it on and the noobs screen came up installed openELEC and rebooted and nothing.
I then put hdmi_safe=1 into the config.ini and that brought up the noobs press shift to enter recovery mode screen so at least that was better than before.
Done the same with the config.ini for openELEC and it got it as far as the xbmc media centre boot screen but then the logo just flashes intermittently and doesn't get any further.
The Pi appears to be functioning correctly because I can see it on my LAN and sharing samba.
Tried the usual tricks such as different cables booting with nothing but power and hdmi cable connected.
Any ideas?
Any ideas?
