I want to rasterbate an image of the periodic table
the space on the wall i have is 1.2m wide by enough height to not worry about it.
1.2m is 5 sheets (landscape) which works out quite well
when it comes to the settings page, what should i set the dots size to? preumeably the dot size is the size of each pixel? so for a periodic table to work, should i set it as low as possible (1mm)? or am i wasting my time trying to rasterbate a periodic table (in a sense that it won't work, not in a sense that it's sad)
this is the image i'm using:
http://www.bpc.edu/mathscience/chemistry/images/periodic_table_of_elements.jpg
thanks for the help
thanks for the help
