Rate My 1st Build
20 Apr 2013
I'm going to be building my first PC soon.
Any Advice and help would be appreciated
Case - BitFenix Colossus
CPU - Intel Core i5 3570K @ (Wanting to overclock to 4.5GHZ)
Motherboard - MSI Z77A-G45
Ram - 2x4GB 1600MHZ Corsair Vengeance
Hard Drive - 1TB Seagate
GPU - 3GB Gigabyte GTX 780
PSU - 700W PSU, Powercool PC-700GT-B, SLI/CrossFire, EPS 12V, Fan, ATX
Cooler - Corsair H100i
Guys Ive changed the Spec take a look
I changed it up a bit and this is my new system spec
What do you think
1x Gainward GeForce GTX 780
1x Intel Core i5-3570K
1x BitFenix Colossus Red
1x XFX Pro 750W Core Edition
1x Gigabyte Z77X-D3H Intel Z77
1x SanDisk Extreme SSD 120GB 2.5" SATA 6Gb/s
1x Corsair Hydro H80i
1x GeIL EVO Veloce Hot-Rod Red 8GB (2x4GB) DDR3 2400MHz
1x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache
1x Corsair AF120 Quiet Edition Low Noise High Dualpack
Total £1,279.93 including Shipping
PSU = to change (this is not branded = troublematic)
motherboard = *might be*too weak for "K" CPU in terms you can o/c more on stronger boards like GD55, or even 65 (depends on particular CPU)
No SSD = waste of hardware
Power Supply raises an eyebrow .... you've got a grands worth of hardware protected by a 40 quid PSU :/
Motherboard questionable.
5/8 = 62.5% = A bare C grade pass. Try better ? Room for improvement
Thanks for advice I'm thinking on getting a 128gb SSD and setup up SRT
With 64gb for windows install and 64gb for faster caching of 1TB HDD
Is air cooling really better than corsairs watercooling h100i rig ?
I really wanted to watercool my cpu but if this CPU cooler is fine ill give it a shot
I'd balance it better, if you gonna spend £500 on a GPU. Better motherboard, PSU is trash, rest is fine, but I'd consider Haswell too.
Thanks but I really wanted to get a great GPU
I don't understand what's wrong with the motherboard I choose it because it supports SLI and crossfire
I would very much like to have a motherboard that supports SLI so later down the line I can have Dual 780s in SLI
My budget was £1000 however I fine spending a little extra for this particular card
The mobo I specced is sli/xfire capable and a decent board for OCing. The Psu is a Seasonic OEM and will be enough to meet all future power requirements. I prefer an aircooler as I think they are much better in terms of price and performance.
If you were to order this before midnight today, then you will save 5% with the discount.
In regards to the 780, before chucking lots of money on one, I would look for some reviews and comparisons, to see if it is really worth it.
It's a bit weak. Meaning, overclocking stability and potential. Usually, you get what you pay for in motherboards.
Again, if you are really serious about a dual 780 setup, it pays to have good quality components that can support them, at a relatively little more expense. Meaning a case with good ventilation, a good PSU, and a motherboard that won't give up when pushed.
£1000 with or without the GTX780? Because having a GPU that is at least 50% the price of your build really isn't worth it.
Yes i have a OS ready to install
What do you think
YOUR BASKET
1 x Gainward GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £549.95
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £167.99
1 x BitFenix Colossus Red LED Big Tower Windowed Case - Black £119.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £109.99
1 x XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply £84.98
1 x SanDisk Extreme SSD 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDX-120G-G25) £83.99
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler (Socket LGA1155 / 1150 / LGA1156 / LGA1366 / LGA2011/ AM2 / AM3 / FM1 / FM2) £76.99
1 x GeIL EVO Veloce Hot-Rod Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (GEV38GB2400C11ADC) £69.95
1 x **B Grade** Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (S (HD-255-SE) £62.4
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
Total : £1,363.92 (includes shipping : £14.75).
This is what you posted, if I'm not mistaken.
I think you specced up this
YOUR BASKET
1 x Corsair HX/TXM Series individually Sleeved Modular Cable Kit - Red (CP-8920008) £17.99
Total : £1,295.72 (includes shipping : £13.75).
£1,279.23 for that
