Hi guys, could you tell me whether you think the airflow is alright in my case? If you see ANYTHING that would improve it then tell me please!
1 intake 120mm fan at the bottom on the front, getting slightly blocked by the HDD's (about half of the fan actually goes over the HDD's)
1 80mm exhaust fan at the back, it's directly in line with the CPU cooler, so the hot air the Akasa fan is blowing through the heatsink is then getting taken away by this 80mm fan.
1 80mm intake fan on the side panel. This is roughly around where the two PCI-e connectors for the graphics card is. It is the lowest and further to the right (front of the case) I can get it. I did think it may be creating a vortex with the graphics card's fan, and after reading some cooling tips on the GTX 470 it seems that attaching an 80mm HDD slim fan (which is what I have on the side panel) directly blowing air into the card's fan seems to knock quite a few degrees of the temp charts.
Temps are as follow
CPU - Idle - 30-31C
- Load - 55-60C
Graphics card - Idle 41C
- Load 91C
Mobo - Idle - 27C
- Load 30C
Hard drives - main drive 27C (top hard drive in the picture)
- storage drive 29C
Please, share your suggestions
Temps are as follow
CPU - Idle - 30-31C
- Load - 55-60C
- Load 91C
Mobo - Idle - 27C
- Load 30C
- storage drive 29C
That's the best I could do really, having an IDE HDD makes cable clutter.
