Rate my TH level 5 CoC base
17 Jun 2012
Is this any good, weaknesses etc?
double walls are pointless in my opinion. If you going for tropheys then you might as well use the double walls and enclose the Town Hall. I'd probably put the archer towers at the corners as well.
Yeah garden ur area for lots of gems especially the rainbow boxes. Enclose all mines and storage in walls and town house, rest put around your outside walls as enemy will target them while ur defences picked em off. Study coverage and make sure all is covered best u can and maybe if u have enough walls enclose ur def units.
