Rate this £1000 build from ocuk
You'll need to get 1 or 2 fans for the CPU cooler, it doesn't come with any.
660Ti is really not that great value for money, you should get a 7950 for that money.
Power supply is one I personally wouldn't get (I'd get a Corsair, OCZ or Seasonic)
From the reviews I've read it seems that the gtx 660 and the hd 7950 are neck and neck in most games, and apparently the hd 7950 would be a better choice when overclocked, but I doubt I will be able to do much of that in a mini-ITX case without the thermals going through the roof so the gfx would have to pretty much run at stock. Also, I don't need 16 gb of ram, 8 is more than enough for me.
Sorry must have clicked the buy button twice :D
Also the 7950 is faster at sock than the 66TI and if your case is properly ventilated (like the one I chose) then its easy to overclock without tremendous heat.
Also didn't realise the Samsung had cashback, definetley worth it then,
You'll want to ask in Customer Services what make of RAM the value RAM is and what size it is. If its to tall it could become a nightmare with cooling options.
Will you be keeping an SSD or not then?
The stock cooler will be fine. Because of the layout of that Asrock mini-itx mobo it's not wise to use tower coolers as they can block the PCI-E slot for the GPU. That's why he had a closed loop cooler in his original spec ;)
I think I will postpone getting an SSD initially and then look to get one later down the line when they get a bit cheaper. I don't think the ram should interfere with the ocuk closed loop cooler.
Ok, they most likely won't be getting any cheaper than now though bud, just a heads up.
Fair point on the RAM if your water cooling.
