Before getting on the phone to Virgin, I thought I'd post here to see if anyone else has had similar issues.
What's happening is while playing certain games (EVE, FFXI), it seems like half of my connection will drop and stop sending data to the server, but receiving part seems fine - the annoying part is that the connection sometimes takes 2-3 mins to realise it's dropped, so EVE will just sit there and not let me do much, FFXI takes a minute to realise something is wrong and then starts dropping the connection indicator (but slowly).
The wierd thing is, while playing World of Warcraft, I occasionally get disconnected/reconnected from/to battle.net, but manage to stay in-game without issue (connecting to the US servers if that makes any difference).
I've done some traceroutes to see if there are any obvious dud hops but as it's somewhat inconsistent as to when it happens, it's been rather difficult to pin down. It feels like it's something out on the internet rather than our own setup, but because it can happen so randomly it's going to be very difficult to diagnose accurately.
The setup I run is Win7 64-bit, wired to a D-Link DIR-615 wireless router and then to the Virgin Cable Modem (not sure exactly what model, it's one with 5 blue status lights on the to). Diagnostics on the CM show that it seems to be within acceptable ranges for power levels and such, the only slightly wierd thing is in the router logs show "Xmas port scan attack" for nearly 400 lines (and that's just from 4am this morning). The router also seems rather slow to load up pages using the web interface. SPI is enabled, UPnP is enabled, WAN ping is disabled and I don't have any rules set up to forward ports to my own machine (nor is the DMZ active).
Does anyone know if there have been connection issues from Virgin Media in say the last month or two, specifically relating to gaming traffic? Or is it likely that something is up with the router and getting a new one would likely help (one of my friends suggested the Linksys E3000)?
Cheers,
Euan
Cheers,
Euan
