Hope you can advise me - I have the Asus A8N SLi SE motherboard.
I noticed what sounded like either something catching or possibly a loose bearing type noise coming from my newly built computer, which I tracked down to the chipset fan (I think - see circled area of picture. Slightly different mobo but it illustrates what I mean).
It only catches intermittently, by that I mean it is pretty constant but does stop every so often (does this rule out it being a bearing inside it). If I press on the top of the fan lightly then it becomes more pronounced. I'm pretty certain its therefore something catching just from the noise of it. What I'm wondering is what I can do here - I don't particularly want to take the computer apart and rma the mobo, cos it took me ages to build and I've just got the stuff I want installed on it (plus it was my first build and I'd quite like to enjoy it for a bit, and don't want to go through the rigmarole of building it again!).
So, firstly, does this sound like something catching on the fan or could it still be something else? Can I easily and safely take the fan off the chipset to see if I can identify what is catching? Would OcUK send me just a replacement fan? Would doing any of this invalidate my warranty?
Also, if I have to return the mobo to get this sorted and they send a replacement, could I just plug my hardware into the new one and it would work fine or would I have to format and reinstall windows and everything again?
