Rayzen 5800X Temps? are these normal
14 Jun 2017
Hi
Just want to know if my temps are normal
Rayzen x5800
MasterAir MA612 Stealth ARGB
In Bios temps almost steady 32C
room temp around 23C
when start my PC in idle 34-40
slight work above 50s
I tried multicore test on CinebenchR23 maximum temp
CPU Tctl/Tdie 85.6
CPU average 85.6
CPU CCD1 86.5
My 5800x Hits 60/62 degrees under full load with a full custom watercooled loop and 2 x 360mm radiators, I'd say thats not bad for an air cooler.
Have you set up the power limits / PBO / CO on the 5800x from the BIOS?
No
I've just found out about this solution
and am gonna apply it
but will not effect the gaming experience, right?
It will, for the better! The cooler it is, the higher it will boost if needed :) mine goes to 5050mhz
Those temperatures are about where I would expect them to be at with a cooler of that sort, it'll be a deal cooler typically if you're gaming on it though, those Cinebench figures for an all core load scenario are an extreme, they really give you a worse case scenario, so you're not likely to do anything that will make your CPU run hotter than that. One thing you do have to bear in mind though is that under a gaming load your GPU will be kicking out heat and this will heat up the CPU aswell to some extent so although the CPU itself isn't generating as much heat the overall heat load of the system will be higher it'll just be distributed differently, airflow patterns will affect this aswell, point being you 'might' see similar temperatures in reality under a heavy gaming load not so much because the CPU itself is working as hard but because the ambient temperature in the case is much higher because of the GPU.
I would say your temperatures are fine and nothing to worry about at all and I'd just get on an enjoy.
Just as a side note, the 5800X shouldn't be compared to either it's predesessor the 3700X or it's successor the 7700X in terms of temperatures really, they are all quite different, the 3700X will typically run quite a lot cooler and the 7700X is a different kettle of fish entirely, if you use the out of the box settings it will sit at 90-95c 'by design' and just clock as hard as it can within that envelope 'sort of'' where as the 5800X does not do that. However you can use 'Curve Optimizer' to influence this quite a lot should you wish to.
