Razer Arctosa Keyboard (Keys won't light up!)
21 Oct 2006
UK
Hi.
I have a Razer Arctosa Keyboard Black keyboard. The keyboard has always lit up with a light blue colour to show which keys you are pressing.
I now only see the wasd buttons lit up right now. Anyone know of a possible way on how I can make all of the keys lit up like before?
Thanks!
I'm pretty sure the arctosa doesn't have backlit keys, it's only the lycosa that does. So if it's the latter, there's a button on the touch panel at the top right, it controls the lights, they can change from being fully on, only WASD or completely off. Also you can install the driver software and change it using that.
As far as I remember from a vid I watched a while ago, there is a touch sensative button in the top right of the keyboard that controls the lights, I think.
