Razer Balde 15 advanced or Alienware m15 R7 or Lenovo Legion 7?
22 Sep 2018
Hello!
I want to buy a new laptop myself.
The following 3 machines which are possible to choose:
Alienware m15 R7:
Specification:
- 15.6" QHD (2560 x 1440) 240Hz 2ms with ComfortView Plus, NVIDIA G-SYNC and Advanced Optimus
- 12th Gen Intel Core i7-12700H (24 MB cache, 14 cores, up to 4.70 GHz Turbo)
- NVIDIA GeForce RTX 3070 Ti 8GB GDDR6 graphics
- 1TB PCIe NVMe M.2 2280 SSD
- 16GB Dual-Channel DDR5 4800MHz Memory
Razer Blade 15 Advanced:
- 15.6 Inch 240Hz QHD Display
- 8-Core 11th Gen Intel Core i7-11800H processor
- 1 TB SSD
- 16GB DDR4 Memory
Lenovo Legion 7:
- Processor: AMD Ryzen 7 5800H
- Display: 2560x1600 500nits, 165Hz, 100% sRGB, Dolby Vision, HDR 400, Free-Sync, G-Sync, DC dimmer
- Memory: 16 GB RAM
- Hard disk: 1000 GB PCI EXPRESS SSD
- Graphics card: NVIDIA GeForce RTX 3070
What do you think is the best choice?
Thanks!
15 Nov 2007
Enfield
The Alienware has the best specs. The Razer has the minimal design. The Lenovo has a good reputation.
Which you go for depends on your use case - as you may be able to choose based on battery life, warranty etc.
