***** RAZER BANSHEE STARCRAFT II GAMING HEADSET ***** ORDER NOW!
20 Jul 2009
The bleak North East arm pit of Britain
Designed exclusively with StarCraft II in mind the Razer Banshee StarCraft II headset takes your gaming audio experience to a whole new level. The Banshee features sound isolation technology to ensure you face no distractions when commanding your elite force of intergalactic military personal. The Banshee has been designed from the ground up compromising nothing when it comes to build and sound quality.
The Banshee is on pre-order now with an expected release date on December the 17th.
Razer StarCraft II Banshee Headset @ £99.99 inc VAT
Designed exclusively for StarCraft® II: Wings of Liberty™ with a focus on maximum sound isolation, comfort and portability, the Razer Banshee provides everything you could wish for in a headset. The Razer Banshee features a newly developed, multi-color APM (Actions-Per-Minute) Lighting System™ that provides real-time feedback about the player’s performance in-game. The Razer Banshee is equipped with a configuration utility for customized adjustments of equalizer, pitch and volume. Other special features include a detachable microphone boom for easy transport and a comfortable circumaural construction, all in a gaming optimized design inspired by the StarCraft II universe.
- Stereo Headphones;
- Circumaural Design with 50mm driver units;
- Volume & Mic Control Buttons on the Headset;
- APM-Lighting System;
- 8 preset EQ;
- Detachable Microphone Boom;
- Braided 7 Foot USB Cable;
- Headphones:
- Frequency Response: 20 -20,000 Hz;
- Impedance: 32Ω at 1kHz;
- Sensitivity (@1kHz, 1V/Pa): >102dB at 1 kHz;
- Max. Input Power: 200 mW;
- Drivers: 50 mm, with neodymium magnets;
- Microphone:
- Frequency Response: 100 -10,000 Hz;
- Sensitivity (-42 dB ±2dB @1kHz, 1V/Pa);
- Signal-to-Noise Ratio: >58 dB;
- Pick-up pattern: Uni-directional"
Only £99.99 inc VAT.
ORDER NOW
