Razer Black Widow Ultimate Gaming Keyboard problem
22 May 2010
Minibotpc
Sooo i just bought one of these today and it was good for the first few hours until i realised the space bar key and the right Alt key was sticking! Spacebar key is catching on the alt key...
Anyone know of this issue? Or am i just unlucky?
I've done a fix... by grinding away abit of the alt key so it can't catch no more and it's done the trick but still for a razer product i wasn't expecting this!
I'm really not sure where the blind faith comes from in Razer products. I've had deathadders and boomslangs and they have all felt cheap and ill-manufactured, with the buttons sticking from time to time.
I've currently got a Razer Tarantula keyboard, and from day one, the ESC key and the Caps Lock key were broken. Caps Lock has a mind of its own, seriously you can blow on it to turn it on and off (infact pressing it normally will trigger it so many times you won't actually know if you've turned it on or off, to use it "normally" you have to gently rock it from the edge closest to A).
Never buying a Razer product again, sticking to Logitech, a company who aren't completely useless.
I've had a fair few products from them before and they've all seemed to be pretty good tbh. Quality isn't that bad, if anything their gaming mouses are pretty well built if not abit fragile looking.
I was just surprised at the built quality of this board compared to its other products since this cost me £103!
