- 8 Feb 2021
- Eastleigh, UK
Hey guys,
I've done a lot of research and think I am fine, but want to pick the brains of this community as Razer forums seem less than helpful. If anyone has a Razer Blade 15" Advanced (2020) with RTX 2080 Super etc, then that would be useful.
I've just placed a pre-order for Razer Blade 15" Advanced QHD - RTX 3080.
QHD is a big factor for me. I currently have an old Alienware m13 OLED QHD. 4K is too hard to power at decent Hz and HD isn't sufficient for software development and other productivity tasks. QHD is the sweet spot IMO.
I seriously considered a ASUS ROG Zephrus G15 as similar specs, but better processor (Ryzen). In the end I decided to go Intel because of Thunderbolt - I like the idea of being able to use an eGPU in the future if I want to.
The point of this. The Razer has no mini-DisplayPort anymore. I have both a HP Reverb G2 and Odyssey G9 monitor.
1. Does anyone know the TDP/TGP for sure? I'm guessing 90-95 (max-Q ranges as per 2080 Super) and similar to the ASUS ROG Zephrus G15? I've seen one Razer Blade 17 review on YouTube that suggests this sort of range, but nothing on the 15".
2. I'm 95% confident that the Thunderbolt 3 port is wired to the RTX and can be adapted to DisplayPort 1.4. This would be a total deal breaker if it wasn't! This should allow me to connect to the Odyssey G9 and hopefully push it at 120Hz+. Does anyone know how the USB-C ports are wired up? Can I get DP Alternate Mode 1.4 out of a USB-C port from the RTX with a suitable cable?
3. Thunderbolt 3 and 4 are very similar from a spec POV. 11th gen H-series Intel with provide TB4, and possibly 2 ports like Evo laptops. Does anyone have any idea when Razer might update laptops to 11th gen, if they are pushing RTX 3080 stuff now?
Any help or educated guesses appreciated!
Thanks,
Michael
Thanks,
Michael
