Razer Deathadder Chroma owners - quick Q
Caporegime
17 Oct 2002
Lancs/London
Hi all,
I just bought a Razer Deathadder Chroma which arrived today but the mouse wheel feels very loose, it has quite a bit of movement left and right and it actually rattles which is a tad annoying when using it.
The lighting also seems to dim when the mouse is lifted up, which worries me about how robust it's going to be in the future. I was wondering if owners of the mouse can please let me know if theirs is similar? I would assume not, but don't want to go down the route of a replacement if it's just the way it is...
Thanks
Aaron
razer produces crap as cheaply as possible, when I bought my chroma left click started double clickking in a few months on 3 new mice ( warranty replacements ), after that I chucked the mouse in the bin, and will never buy anything razer again, vote with your dollar and avoid cheap crap like razer.
I tried to get used to it but it's really annoying, it makes a crazy noise when moving the wheel, or just moving the mouse so it's getting returned, I find it hard to believe every Chroma mouse is built like that. Very poor.
I have one of these and wouldn't buy another, feels cheap and the wheel click sometimes doesn't work, it's only around 18 months old too.
Thanks all, it's going back for sure. If that's how they all are it would be unacceptable but I just believe it's a dud, as above very poor build quality.
