Razer Deathadder...how to disable lighting ?
9 Nov 2005
manchester,uk
Hi
I have a Razer Deathadder V2 mouse and for some reason the scroll wheel is suddenly lit up with a random colour. I have looked in the software but can't see any way of disabling it :confused:
Anyone got any ideas ?
Thanks
Can you not disable it in the effects drop down list?
What happens if you set brightness to 0?
Wonder if any of the 3rd party RGB software would do it?
It seems to have a mind of it's own. It is currently not lit up, but when I started the pc up it was a random colour. Nothing in the lighting menu seemed to affect if. I have the brightness set to zero and white (Static).
I had a similar issue when a Razer software update failed, I think I either forced the update or reinstalled to fix it.
