Razer Exactmat + wireless mouse?
20 Jan 2004
Bristol
I’m thinking of getting a Razer Exactmat but have heard a rumour that you can not use a wireless mouse with this mat? I can not see why this would be a problem but want to check.
Does anyone have a Exactmat and a wireless mouse?
Cheers
just an update
I got the exactmat and its a solid bit of kit although I can not tell the difference between the speed and control sides (appart from the texture of the surface:rolleyes:) anyway both my wireless and MS sidewinder work excelently on it. Only critisism is that it is blooming cold, I have to put in a couple of hours of gaming before it warms up;)
Should get the wrist rest to go with it. I am using that rest with the Razer Dominator pad. It really is good.
As for the sides that is it. The texture. Smooth for speed and Rough for control.
