Razer hp-1 headset and onboard sound
18 Feb 2007
Northants
i got this headset froma a mate who didnt like em only had a week or so.
anyway when im using in game comms teamspeak whenever i try to speak all they can hear is the in game noise.
so i tried it by recording via teamspeak and playing a film, the same all you can hear is the film.
when im on desktop i can be heard no worries,
im using the realtek hd onboard sound on a gigabyte ds3p tried all various settings but still no joy.
anyone else have any ideas
If using XP then:
Start > All Programs > Accessories > Entertainment > Volume Control
Options > Properties > Adjust Volume for (Recording) > Check all under 'Show the following volume controls' > OK
Make sure the only slider with a check under it is the microphone one.
Hopefully that will sort it...
nope tried all that still no joy and yes its xp im using,
i had it with my prevoius headset but when i muted stereo mix on the last headset it was fine this time its having none of it
Check in control panel for applets relating to your specific sound hardware, they often have similar settings and unless it's turned off on both it'll continue mixing inputs.
well got a sound card today the auzentech xplosion 7.1 and thats the same i just cant seem to work it out im wondering if there is an issue with the razers and this happening ill guess ill have to get incontact with razer and have 5 emails before i get near the answer i want
might be the razers, mine are perfect-o!
are you using a sound card or on board sound?
any chance you could post a img of your sound settings to see if ive been dumb and missed something please.
as i emailed razer and they are class as normal.
