Razer Keyboard and Mouse
the problem with wireless is that it could run out in the middle of a fps match and u could die :D i have a razer copperhead mouse and its awesome had no problems with it :)
For wireless, I'm using the razer mamba. It's a fantastic product and I do recommend it. I liken it to having a logitech g9 without the wire, and a better shape. If the price doesn't put you off, take a look.
also just noticed there isn't a wireless razer unless I spend in the £100 mark. I can understand the issues concerning wireless but I'll have to use usb extensions to reach the tower (no really a concern) but it's just the tidy aspect and the fact that sometimes in fps the wire can get in the way :(
hmm, still looking lol
Is there anything better than the death adder for performance/price, not actually fussed over manufacturer now
thanks
ahh i see your problem now :) maybe wireless is the way to go :)
The wire getting in the way was my biggest prob that the mamba solved, although using a mouse bungee can achieve this quite well too.
