** RAZER LEVIATHAN 5.1 SOUND BAR BACK IN STOCK**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
The RAZER LEVIATHAN has landed back into stock today after 2 months of waiting for stock to arrive. After Pre-orders have been filled we have a few remaining so get you order in quick to avoid missing out on the available stock. It may be a while before the next lot of stock arrives.
Razer Leviathan Dolby Pro Logic 5.1 Channel Gaming Sound Bar @ £164.99 inc VAT
The Razer Leviathan 5.1 Channel Surround Sound Bar easily fits under any desktop monitor or living room console setup. Versatile enough to be repositioned constantly in any situation, this sound bar features cutting-edge Dolby® technology, superior sound drivers, and a dedicated subwoofer, projecting rich sounds that recreate epic in-game battle scenes or just streaming your favorite tunes from your smartphone.
Enjoy a rich, full-range 5.1 true-to-life surround sound experience with the Razer Leviathan, powered by the award winning Dolby® Virtual Speakers. No matter your source type (stereo or multi-channel audio via optical input), Dolby® Digital will convert audio from your sound card, console or set-top
The Razer Leviathan seamlessly connects to your Bluetooth devices via Bluetooth v4.0 with the award winning aptX® technology for audio quality indistinguishable from a wired connection with an impressive dynamic range. With a connecting range of up to 10 meters, you can enjoy your music without the hassle of wires. The Razer Leviathan also remembers your recently paired devices, allowing you to quickly connect with a single tap. The built in NFC technology allows for ultra-fast pairing.
With a powerful 5.25” downward firing subwoofer dedicated specifically for the accurate reproduction of bass, and tuned to produce distortion-free lower frequencies, the Razer Leviathan is made to deliver chest-thumping, deep impact bass. Synergizing with 2 perfectly tuned full ranged drivers and 2 tweeters in the sound bar, the Razer Leviathan lets you experience the entire spectrum of sound by providing crystal clear mids and impressive highs.
Dolby® Virtual Speaker is the technology that enables the Razer Leviathan to deliver 5.1 virtual surround sound via its two speakers by converting stereo and digital 5.1 channel audio into 5.1 virtual surround sound.
Dolby® Digital (AC-3) is used to decode analog sound (5.1 or stereo) from an optical source and convert it into digital information allowing Dolby Virtual Speaker to reconvert this digital information into virtual surround. 5.1-channel Dolby Digital provides two surround channels to Dolby Surround’s one for more precise localization of sounds.
Dolby® Pro Logic® II expands stereo content from all sources (Analog, Optical, Bluetooth) into 5.1 channel surround sound. After being expanded into 5.1 channel surround, Dolby Virtual Speaker will convert the expanded stereo files into virtual surround sound.
Features:
- Space saving design for versatility
- Multiple connection methods via analog, optical or Bluetooth v4.0 aptX®
- Adjustable tilt angles (0°,15°,18°) for optimal sound
- 3 preset equalizer modes tuned for gaming, music and movies
Sound Bar Specs
- Total power output : 30W (15W x 2RMS)
- Full range drivers : 2 x 2.5” / 63.5mm
- Tweeter drivers : 2 x 0.74” / 19 mm
- Impedance : 8O
- Frequency response rate : 180Hz – 20KHz
- Approximate weight : 4.4lbs / 2Kg
Subwoofer Specs
- Type : Passive
- Total power output : 30W RMS
- Full range drivers : 5.25” / 133mm
- Impedance : 8O
- Frequency response rate : 20Hz – 180Hz
- Approximate weight : 5.1lbs / 2.35Kg
Only £164.99 inc VAT.
ORDER NOW
View our entire sound bar range here
Yes it will be a alternative option to desktop speakers it performs in the same way but In my opinion it is better as the speaker is portable and has many functions.
When gaming it will sit under the monitor to give you the best sound experience which will work the same if you wish to watch TV just hook it up and leave it underneath.
The good thing about it is that it comes with a sub unit as well to give you that extra base if you need it but this sound bar alone packs a punch.
Awesome for music as well. You can take it anywhere with you even if it is round a mates house to show him what he is missing while gaming.
The sound bar itself has some powerful bass but the sub helps give it that extra power over your normal sound bars.
I can vouch for the Leviathan, I've found it is more suited it is more suitedto music than films.
The bass is insane but never sound over the top. I have mine in the living room, hook it up to my iPhone via Bluetooth and enjoy!
