I've just bought a Razer Lycosa from OCUK which turned up yesterday. The keybaord itself it absolutely fantastic and looks the part, however I've been experiencing some wierd problems with it. Every now and then whilst typing the keyboard decides to disconnect/reconnect (backlight goes off, and you have to turn it back on via software), then the shift key doest work and holding down keys does not work, you have to keep tapping it if you know what I mean, not good when youe playing FPS online!
I wanted to know if anyone else has had this problem and is there a fix. There doesnt seem to be a firmware update in on the Razer website!?
