Ok, I've had my LYcosa for just over 2 months now, it's been perfect sicne I bourght it.
Recently though, I've been ahving the following issues:
1. Occasionly while using a music player I have the touch panel set to, it will continuousely skip songs forward or back without me pressing a button, the only fix I've found it to either set the touch pad toa media player I dont have or unplug and plug in the keyboard. This is especialy annoying because even if the player isnt open it opens it.
2. Occasionly buttons will stop working, I was playing mirrors edge and the space bar stopped working for instance, unplug and plug in fixed it, but this happens with other keys as well.
Can anyone tell me if they have had these problems? Also the problem is very inconsistant so I'm worried if I RMA is they won't find a problem and just send it back because they were lucky.
