Razer Lycosa keyboard - keeps launching media player
18 Oct 2002
Pembrokeshire
Just started using this keyboard and it insists on launching Media player endlessly.
I have to restart the PC and its fine for a bit then sets off again. Anyone had this problem?
I've got the tarantula and have never had this problem. If its a similar layout i think their is a media player button somewhere on the keyboard so maybe its jammed? Only other thing is check the razer software to see if you havent accidentally set a key override or macro to open it.
Had a quick look on the web and it seems older versions had an issue with opening media player randomly. Well mine was doing this but its stopped now. Nothing was jammed.
Cross fingers its OK, I umm'ed and ah'ed over this keyboard due to the price so don't want it to give grief.
I know the feeling spending this much on a keyboard is kind of a tough decision so it needs to be perfect.
Glad you got it sorted anyway :D
