Razer Lycosa
22 Apr 2011
Hi,
I updated to the latest version of the driver for the Razer Lycosa Keyboard. (only just got it, so had the version off the CD)
The system tray icon loads, but if I double click it, the configurator doesn't load.
Also tried loading from start menu, but that doesn't work!
I've tried rebooting, but same thing. I can't get it to load?
Any ideas?
Release Log:
- Fixed an issue where the system tray icon disappears after applying changes.
- Configurator will no longer be able to open when the hardware is not present.
Might be something to do with this, which is for the latest v3.02 drivers.
Have you tried ending all the razer processes in task manager then restarting them?
nvm, just realised you have tried restarting. Have you tried disconnecting and reconnecting the Lycosa once booted?
Similar to another recent post i replied to. Just use the drivers that worked for you. Newest aint the greatest when it comes to Razer drivers.
I'm still using the CD drivers because of issues on ALL updated drivers.
