Razer Mamba Issues
8 Apr 2009
Manchester
So I bought this in January and at first it was great, then I noticed the cursor would move on it's own and it was not accurate.
I was then sent a replacement and again it worked fine for a few weeks and now I have the same problem.
it is really bad can't even get the cursor where I want it.
Anyone experienced these issues and would other gaming mouse would you recommended? for the price this is definitely not worth it.
Is this the wired or wireless version ? If it's the wireless one plug it in with the wire and see if the problem persists.
I have the wired version and every now and again it will move on its own.
Once it can move freely enough i'm going to take it to work while i sit back and watch it do my daily chores.
A good vigorous shake stops it moving
I did, until I uninstalled Razer Synapse, now it runs like a dream.
Recently reinstalled Synapse to change some of the colour settings, the cursor immediately started behaving erratically.
So if you have Synapse installed, it's probably that garbage piece of software.
I do have the software installed, if you uninstall it how are you supposed to change the mouse settings lol
Change them to how you want, then uninstall. The settings will stick. If you want to change them, reinstall.
But of a ballache but it'll fix your problem, probably.
I never change my settings and hate the software; this is really good to know!
Will setup my deathadder elite lights and DPI then uninstall this junk.
Yup that's all I do, set the colours in Synapse then uninstall. Worst piece of software I've ever used. Razer software used to be a lot better before all this cloud bs.
